Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Suspension, Steering & Brakes
Become a Supporting Member         Become a Preferred Vendor
Advertisements
Suspension, Steering & Brakes Brake Repair, Disc Brake Conversions, Suspension Replacement, Steering & Alignment
User Tag List
Reply
Thread Tools Display Modes
Old 04-19-2017, 02:48 PM   #1
theblindchicken's Avatar
theblindchicken
Senior Member
Year: 1974
Model: K10 5" lift
Engine: 350-4
theblindchicken is on a distinguished road
Default No gears with non-tilt column (74 k10 w/ th350)
Recently put a body lift on my truck, now the shifter won't engage the transmission.
Prior to body lift, the shifter engaged everything just fine. Immediately after body lift, only was able to select between P R and N. It would not engage Drive, 2nd or 1st even though the shifter could be rotated til about 4-5 o'clock. Engaged Park, Reverse, and Neutral just fine though.
Assumed it was an issue being that the trans linkage had not been lengthened yet. Proceeded to lengthen it the 2" necessary while ensuring the linkage was clocked the same as factory.
Proceeded to reinstall, still had P R N, no D 2 1.
Figured it may need some adjusting, loosened the linkage at the trans, set both the trans and Steering column in Park, then tightened it back up.
No dice. Now the steering column won't engage any gear. Column won't shift without key in ignition, but selecting a gear doesn't translate to the tab or linkage. Steering column shifter can be set anywhere, and the trans can still be engaged by manually rotating the steering shaft tab to select the gear.
No problem with trans, only with steering column. Guessing the shift tube is busted. Where can I find a new one? Or is it easier to get another column?
__________________
1974 K10 - 350/TH350/NP203
5" Front / 4" Rear + 2" Body on 35's KO2's
"Fix it 'til it breaks, then fix it some more."
theblindchicken is offline   Reply With Quote
Old 04-19-2017, 05:42 PM   #2
chengny's Avatar
chengny
Senior Member
Year: 1986
Model: K3500
Engine: 350/5.7
chengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond repute
Default
Try adjusting it again.
This time (after loosening the locking bolt at the transmission end of the linkage) rotate the transmission shift lever fully clockwise to the "P" position and then rotate it CCW two clicks to the neutral detent.
Go up to the column gear shift lever and rotate the lever until you feel it drop into neutral gate notch. Do not use indicator pointer as a reference to position shift lever.
Go back down to the transmission shift lever and tighten the locking bolt.
chengny is offline   Reply With Quote
Old 04-20-2017, 02:38 PM   #3
theblindchicken
Senior Member
Year: 1974
Model: K10 5" lift
Engine: 350-4
Default
Appreciate the added info. I'll give it a whirl after class today.
My biggest concern is that the shifter doesn't seem to engage the shift tab:
__________________
Old 04-20-2017, 06:57 PM   #4
theblindchicken
Senior Member
Year: 1974
Model: K10 5" lift
Engine: 350-4
Default
Seems more and more like its a busted shift tube.
Took the linkage loose at the trans bracket. Was able to go between gears with no issue. Full movement at the linkage tab on the steering column. Set it in neutral, set the trans in neutral by hand, and tightened them both back together. Went to shift through the gears.... no dice. No movement transferred. Dad said it was slightly wiggling when going back and forth through the gears.
Looks like its busted somewhere between the shift lever and the linkage.
Sent from my SM-G935P using Tapatalk
__________________
Old 04-21-2017, 05:41 AM   #5
Rusty Nail's Avatar
Rusty Nail
Senior Member
Year: 1975
Model: K5 Blazer
Engine: 350/350/203/D44/12bolt/3.73
Rusty Nail has a spectacular aura aboutRusty Nail has a spectacular aura about
Default
"the neutral detent"
__________________
1975 K5 Blazer Cheyenne
1977 C20 Silverado
1987 Monte Carlo SS
Rusty Nail is offline   Reply With Quote
Old 04-23-2017, 03:47 AM   #6
theblindchicken
Senior Member
Year: 1974
Model: K10 5" lift
Engine: 350-4
Default
Taking a look at the shift tubes that some other trucks use, it appears that there's a key race on the tube that locks the shift tab in sync with the column shifter.
Basic knowledge always states that a part will always fail at the point where all the force and torque is applied, i.e. the key race/shift tab. Is the race cast/machined with the shift tube or is it separately pressed in with the tab slipped over it and held in place via the spring and/or lock nut?
__________________
Old 04-23-2017, 04:57 AM   #7
chengny's Avatar
chengny
Senior Member
Year: 1986
Model: K3500
Engine: 350/5.7
Default
I was wondering how you were coming along with this.
In addition to the keyed interface between the shift tube and the gear shift bowl, there appears to be another - even weaker - group of couplings integral with the shift tube itself:
I don't know how many plastic couplings there are or exactly where they are located, but I took an educated guess and circled possible locations in blue. The red tracers depict the key and keyway:
Parts list for above:
Assembly instructions. Note step 10:
Old 04-23-2017, 10:44 PM   #8
theblindchicken
Senior Member
Year: 1974
Model: K10 5" lift
Engine: 350-4
Default
As always, @chengny;, greatly appreciate you taking the time to help out.
I've gotta focus on school at the moment, so not much free time in getting the truck rolling right now. Definitely been trying to find ANY part number for the shifter tube/shaft, and that's so far been a no go. Doesn't seem to be that anywhere has part numbers listed for these.
__________________
Old Today, 03:37 AM   #9
chengny's Avatar
chengny
Senior Member
Year: 1986
Model: K3500
Engine: 350/5.7
Default
Originally Posted by theblindchicken View Post
As always, @chengny;, Definitely been trying to find ANY part number for the shifter tube/shaft, and that's so far been a no go. Doesn't seem to be that anywhere has part numbers listed for these.
P/N for Gear shift tube (no. 30 above) = 7814357. Not too hard to find. Here is the first one I checked - NOS/NIB for $95:
http://www.ebay.com/itm/NOS-1973-197...-/351823800669
Just from what I can see in the dwgs, the shift tube appears to be the problem. I would hold off on the steering shaft (no. 38 above) as it doesn't seem to be involved in gear selection.
Old Today, 05:45 AM   #10
HotRodPC's Avatar
Year: 85
Model: Silverado K10 to K20 Conversion
Engine: 6.2 to Gas???
HotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond repute
Send a message via Yahoo to HotRodPC
Default
For me, it would be a good excuse to buy a B&M Quicksilver ratchet shifter. There's others that are cheaper too if you want to go with that bigger expense, but I sure liked the Quicksilver for racing.
__________________
UNDER CONSTRUCTION
84 Chevy Silverado C20 454/Turbo 400 14FF 3.73 Peg Legger -- http://www.gmsquarebody.com/forum/showthread.php?t=286
85 Chevy Silverado K10 350/700R4/NP208 14FF/10B 4.10 w Lockers --http://www.gmsquarebody.com/forum/showthread.php?t=279
HotRodPC is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
CA-84-up auto tilt column $100 85c10owner For Sale 8 04-14-2017 04:35 PM
tilt column swap peats Introduction 0 12-02-2016 04:20 PM
Need a dimmer rod for my tilt column circuitguy Wanted 11 10-24-2014 02:30 PM
How much for tilt column? Green79Scottsdale Suspension, Steering & Brakes 11 07-24-2014 07:14 PM
84' auto tilt column tanz45 For Sale 0 10-12-2013 04:20 PM
