Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Differential & Driveline
Become a Supporting Member         Become a Preferred Vendor
Advertisements
Differential & Driveline Front and Rear Axles, Lockers, Limited Slip, Yokes, etc
User Tag List
Reply
Thread Tools Display Modes
Old 01-10-2017, 09:25 AM   #1
Hoodless
Year: 86
Model: k20 c10
Engine: 350/454
Hoodless is on a distinguished road
Default Front axle shafts joints
Are the front axle u joints 1350's?
Truck is a combination of multiple years but the axles and all the shafts are what is supposed to be so I have been going with 86 model year. Part numbers for all the u joins would be fantastic, found some numbers in other threads but nothing solid on the front shafts.
Thanks
Sent from my SAMSUNG-SM-N910A using Tapatalk
Hoodless is offline   Reply With Quote
Old 01-10-2017, 10:22 AM   #2
87scotty's Avatar
87scotty
Senior Member
Year: 1987
Model: V20
Engine: 5.7 for now
87scotty has a spectacular aura about87scotty has a spectacular aura about
Default
To me always seems like theres 10 diffrent options i get them all return what i dont use! Or pull em before going to the store
87scotty is offline   Reply With Quote
Old 01-10-2017, 11:03 AM   #3
kickdeez
Senior Member
Year: 1990
Model: Suburban 2500
Engine: 454 tbi
kickdeez is on a distinguished road
Default
What axle is in the front of your truck?
kickdeez is offline   Reply With Quote
Old 01-11-2017, 07:52 PM   #4
Hoodless
Year: 86
Model: k20 c10
Engine: 350/454
Default
10 bolt
Old 01-16-2017, 08:04 AM   #5
kickdeez
Senior Member
Year: 1990
Engine: 454 tbi
Default
Tell the parts store person you have an 86 K10, and you should get what you need.
Old 01-16-2017, 09:54 AM   #6
crazy4offroad's Avatar
crazy4offroad
Senior Member
Year: 1977
Model: One-Ton K-10
Engine: 350/TH350/NP205
crazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud of
Default
Dana Spicer 5-760X
http://www.dennysdriveshaft.com/p176...hevy_and_.html
__________________
Montani Semper Liberi
77 SWB "ONE-TON K10" - 6" Front Superlift Springs/Rear ORD Shackle Flip 38" TSLs on 15x10s
Welded 14-bolt FF w/Disk Brakes - D60 Front w/ORD X-over Steering, HD Shackles/Grease Bolts
TH350 dual-feed HD trans & NP205 tcase with 32-spline front output mod
79 SWB K10 "Dad's Truck" - Pretty much stock except front push bar, new sliding rear window and bedliner
crazy4offroad is offline   Reply With Quote
Old 01-18-2017, 09:09 AM   #7
Hoodless
Year: 86
Model: k20 c10
Engine: 350/454
Default
Thanks gents!!
Old 01-20-2017, 12:04 PM   #8
Hoodless
Year: 86
Model: k20 c10
Engine: 350/454
Default
I tell you what, dennysdriveshaft is really a great company to deal with, fast and friendly service!!
Old 01-20-2017, 05:29 PM   #9
crazy4offroad
Senior Member
Year: 1977
Model: One-Ton K-10
Default
Yep, and I like they have the detailed graphic of the part's dimensions on their website.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
What U joints for front driveshaft np208 + 10 bolt adamj Differential & Driveline 8 02-03-2016 07:54 PM
Replacing Front Droveshaft Joints theblindchicken Differential & Driveline 0 12-04-2014 03:12 PM
Front Axle help Denvernic Differential & Driveline 4 02-23-2014 11:06 PM
K20 front driveshaft U-joints cramezl Front Diff & Hubs 1 12-04-2013 10:37 AM
front axle ball joints 86chevyk20 Front Diff & Hubs 5 03-04-2013 12:27 AM
