Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Transmission & Transfer Case > Transfer Case
Become a Supporting Member         Become a Preferred Vendor
Advertisements
User Tag List
Reply
Thread Tools Display Modes
Old 12-31-2016, 02:46 PM   #1
adamj's Avatar
adamj
Senior Member
Year: 1987
Model: V20 Suburban
Engine: 5.7L TBI
adamj will become famous soon enough
Default Transfer Case Skid Plates
I picked up a transfer case skid plate that I thought would fit, and went through all the trouble of cracking the bolts, and bringing it home, scrubbing it down to get all the dirt off, and then find out it doesn't fit... It came from an 80s suburban. I guess there are different transmission cross members because the holes just didn't line up. I have a sb350 + NP208 + SM465. Can anybody tell me which transfer case skid plates will fit? I have the wavy transmission crossmember and no rear cross member. That is another style I have seen, but I believe it is only for 73-79? vehicles with that style of skid plate.
If anyone wants this one, I will send it out, just pay for shipping, it has the bolts too.
__________________
'87 V20 Burb Build
adamj is offline   Reply With Quote
Old 12-31-2016, 06:45 PM   #2
ajdemello
Year: 87
Model: k10
Engine: 350
ajdemello is on a distinguished road
Default
I had the same issue! I had a skid plate on my 86 v6 sm456 208. I sold that crossmember but kept the skid plate then I tried to put the plate on a crossmember from a 87 v8 700r4 208 truck and it don't fit right either
Sent from my SPH-L720T using Tapatalk
ajdemello is offline   Reply With Quote
Old 12-31-2016, 07:42 PM   #3
yevgenievich
Senior Member
Year: 1991
Model: V2500 burb
Engine: 5.7
yevgenievich is a jewel in the roughyevgenievich is a jewel in the roughyevgenievich is a jewel in the roughyevgenievich is a jewel in the rough
Default
Interested in giving it a try on 241 tc. How much shipped to 77802?
__________________
1991 GMC V2500 Suburban
1967 Camaro future 305tpi/700r4, past 468 bbc/th350
1989 Trans Am ls1 t56
1992 Dodge Stealth base
1994 c3500 350/4l80e
Sold a bunch
Originally Posted by skysurfer View Post
Good rig for robbing banks.
Witness one: "He was in a white Chevy."
Witness two: "You're crazy, it was a blue GMC."
yevgenievich is offline   Reply With Quote
Old 01-01-2017, 06:54 PM   #4
bucket's Avatar
Year: '77, '79, '84, '88
Model: K5, K30, C10, K20 Burb
Engine: 350-454
bucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond repute
Default
Looks like it's for the style of crossmember that dips down on on both sides, rather than one. I think it was used in '85-'86.
__________________
'77 K5
'79 K30
'84/'78 C10
'88 Suburban
+ a car or two
"Faster horses, younger women, older whisky, more money"
bucket is offline   Reply With Quote
Old 01-04-2017, 03:38 AM   #5
adamj's Avatar
adamj
Senior Member
Year: 1987
Model: V20 Suburban
Engine: 5.7L TBI
Default
Is there a thread on the different crossmembers that were used? Through the years, with what transmissions, the different GVWR's, C vs K, etc.
__________________
'87 V20 Burb Build
Old 01-04-2017, 03:44 AM   #6
adamj's Avatar
adamj
Senior Member
Year: 1987
Model: V20 Suburban
Engine: 5.7L TBI
Default
I think it can fit in a large flat rate box from USPS, and it would be $18.75 to 77802, but I need to measure first to confirm.
__________________
'87 V20 Burb Build
Old 01-05-2017, 10:44 PM   #7
bucket's Avatar
Engine: 350-454
Default
I don't think so, but it didn't start getting confusing until the 80's, when concerning the K series. Earlier crossmembers were basically the same, with the K30 part being more flat than the 10-20.
I think the C series were all the same, except probably the C30 (again, taller rails than 10-20 trucks).
__________________
'77 K5
'79 K30
'84/'78 C10
'88 Suburban
+ a car or two
Old 01-06-2017, 04:48 AM   #8
yevgenievich
Senior Member
Year: 1991
Model: V2500 burb
Engine: 5.7
Default
I have been looking under the suburban and can't see where the center bolt would go? The outer ones look like they should line up with the cross member. How does it not fit on yours?
__________________
Sold a bunch
Old 01-06-2017, 03:09 PM   #9
skysurfer's Avatar
skysurfer
Senior Member
Year: 1989 Suburban
Model: V2500
Engine: 5.7/TH400/NP241C
skysurfer has a reputation beyond reputeskysurfer has a reputation beyond reputeskysurfer has a reputation beyond reputeskysurfer has a reputation beyond reputeskysurfer has a reputation beyond reputeskysurfer has a reputation beyond reputeskysurfer has a reputation beyond reputeskysurfer has a reputation beyond reputeskysurfer has a reputation beyond reputeskysurfer has a reputation beyond reputeskysurfer has a reputation beyond repute
Default
The one on my '89 has a similar shape to the one above but isn't exactly the same. It has two drain holes in the bottom and mounts with just the four bolts on the crossmember.
skysurfer is offline   Reply With Quote
Old 01-06-2017, 04:52 PM   #10
1low4x4's Avatar
1low4x4
Senior Member
Year: 1984
Model: K10
Engine: 5.7
1low4x4 is a splendid one to behold1low4x4 is a splendid one to behold1low4x4 is a splendid one to behold1low4x4 is a splendid one to behold1low4x4 is a splendid one to behold1low4x4 is a splendid one to behold1low4x4 is a splendid one to behold
Default
Here is the one on my truck
File Type: jpg 13344752_1194875927218684_732110809932555395_n.jpg (89.0 KB, 1 views)
__________________
1985 K10. 4" Rancho lift, 35 Toyos, 350 w/flat top pistons, vortec heads, 212/212 cam, Qjet, Hooker longtubes, true dual super 44s, 4.10 gear, NP208, 700r4, efans, 4 core radiator, trucool40k trans cooler, ORD greasable shackles, Tuff country shocks, ORD swaybar extensions
1low4x4 is offline   Reply With Quote
Old 01-06-2017, 07:36 PM   #11
adamj's Avatar
adamj
Senior Member
Year: 1987
Model: V20 Suburban
Engine: 5.7L TBI
Default
My apologies, I should have mentioned this, but I just put an extra bolt that I had in that hole - it doesn't do anything, just a drain hole. It mounts just like skysurfer posted, the 4 bolts and nuts that mount to the crossmember.
__________________
'87 V20 Burb Build
Old 01-06-2017, 11:21 PM   #12
yevgenievich
Senior Member
Year: 1991
Model: V2500 burb
Engine: 5.7
Default
I will take it if can be $20-$25 shipped. You can also just send it without a box with corners wrapped a bit if that comes out cheaper.
__________________
Sold a bunch
Old 01-17-2017, 11:31 PM   #13
adamj's Avatar
adamj
Senior Member
Year: 1987
Model: V20 Suburban
Engine: 5.7L TBI
Default
Let me know if you got it and if it fit your crossmember and the 241, I'm interested to know.
__________________
'87 V20 Burb Build
Old 01-19-2017, 11:09 PM   #14
yevgenievich
Senior Member
Year: 1991
Model: V2500 burb
Engine: 5.7
Default
Looks like same as yours. I might give a shot at modifying it to fit at a later time.
__________________
Sold a bunch
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Transfer case help!! Ypsik10 Tech Discussion 7 12-09-2016 09:17 PM
How low is your transfer case? firebane Suspension, Steering & Brakes 9 08-29-2015 11:18 PM
Transfer case 79scottsdale400 Transfer Case 13 03-27-2014 03:20 AM
Transfer case Id towjoe Transmission & Transfer Case 11 03-03-2014 12:43 AM
transfer case rtgs Transfer Case 5 03-08-2013 10:41 AM
