Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Transmission & Transfer Case > Automatic Transmission
Become a Supporting Member         Become a Preferred Vendor
Advertisements
User Tag List
Reply
Thread Tools Display Modes
Old 03-21-2017, 12:20 AM   #1
Handy Andy
Year: 1986
Model: sierra 1500
Engine: 400
Handy Andy is on a distinguished road
Default 700r4 cross member spacers
Ok, so I had to drop my transmission to send it off to be rebuilt and swapped to a new case because the old case was cracked. When i went to pull the cross member I noticed that the bolts had spacers on them, but they were not between the cross member and the frame rails. The cross member was tight up to the frame rail. Is that right? It doesn't seem like it would be right. Why would they have spacers there if they weren't supposed to be between the cross member and the frame rail? When I installed the transmission and cross member I put the spacers back where I thought they should be, in between the cross member and they frame. I'm hoping this is right.
Handy Andy is offline   Reply With Quote
Old 03-21-2017, 01:47 AM   #2
VAL's Avatar
VAL
Senior Member
Year: 1986
Model: K10 SILVERADO
Engine: 5.7
VAL is a jewel in the roughVAL is a jewel in the roughVAL is a jewel in the roughVAL is a jewel in the rough
Default
I had the same deal, spacers were on top. couldn't figure out why. When I put on my 6" lift, I installed the transfer case lowering blocks, I probably could have used the spacers it had, but decided against it.
VAL is offline   Reply With Quote
Old 03-21-2017, 07:48 AM   #3
The reaper's Avatar
The reaper
Senior Member
Year: 84,79,70
Model: Suburban k10, bonanza k10, c10
Engine: 400, 350, 350
The reaper has a spectacular aura aboutThe reaper has a spectacular aura aboutThe reaper has a spectacular aura about
Default
It is correct. The spacers DON'T go between the crossmember and the frame rail.
The reaper is offline   Reply With Quote
Old 03-22-2017, 11:49 AM   #4
Handy Andy
Year: 1986
Model: sierra 1500
Engine: 400
Default
Ok, next question, am I hurting anything by having the spacers between the cross member and the frame? As far as I can tell all it did was decrease the angle on the driveshaft and that's generally a good thing right?
If I gotta swap them back the way they were then oh well it will only take 5 minutes, but if I can I'd like to leave it the way it is.
I'm not 100% sure on this but less angle in the drive line equates to more power at the back wheels right?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need Pics of Engine Cross Member kickdeez Suspension, Steering & Brakes 9 04-29-2016 08:16 AM
2wd Dual Exhaust Transmission Cross-Member scottybaccus For Sale 6 11-22-2014 01:38 AM
700r4 aftermarket cross member newmexicosaint Automatic Transmission 1 11-11-2014 11:21 PM
Damged cross member 87ChevyR10 Transmission & Transfer Case 8 12-24-2013 02:12 AM
1 ton transmission cross member kleedus Wanted 8 03-25-2013 06:31 PM
