Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Engine & Performance > Engine Swaps (Gas) LS, Vortec, LT1 , etc.
Become a Supporting Member         Become a Preferred Vendor
Advertisements
User Tag List
Reply
Thread Tools Display Modes
Old 03-03-2017, 07:17 PM   #31
Camar068's Avatar
Camar068
Year: 1986
Model: K10/350/700r4/np208/3.08/31"
Engine: 10 yrs Air Force
Camar068 is just really niceCamar068 is just really niceCamar068 is just really niceCamar068 is just really nice
Default
Woohoo! Got the taxes in and ordered a butt load of parts. Time to get started on this thing! Again I'll be prepping the engine on a test stand prior to install.
I've got to run fuel line, install tank/sender/pump (rear burb tank mod), mod the tail light for fuel filler before I even attempt to install it. Still gonna be a few months, but at least we have the majority of the parts I needed ordered.
mounts $105 Dirty Dingo
LS motor lift plate $50 Dirty Dingo
starter $57 DB Electric brand Amazon
radiator/fans $93 Amazon
Fuel line to tank $25 Autozone PAC-625
speed, reluctor ring $6 Rock Auto ACDELCO 24202711
speed sensor $16 Rock Auto ACDELCO 2131701
Spark plugs $46 RockAuto
spark plug wires, $41 RockAuto
intake gasket $40 Rockauto Felpro
Gas tank and straps $114 Rockauto spectre 31 gallon
Fuel Pressure regulator $44 Rockauto wix 33737
neutral safety switch $43 RockAuto
Fuel pump $62 Rockauto acdelco ep381
fuel sender $77 Rock auto 1987 Spectra 31 Gallon
Shipping Rockauto $18 Rockauto Shipping (GMSB discount on total removed from shipping costs for easier tracking on spreadsheet)
__________________
Man....I don't even have an opinion
Oh $h!7 I shot Marvin in the face!
...My name is Paul and this is between Ya'll
Camar068 is offline   Reply With Quote
Old 03-06-2017, 09:19 PM   #32
Camar068's Avatar
Camar068
Year: 1986
Default
Got the dingo's in today. Kudo's to them shipping fast, I went with them standard shipping. I ordered them Friday. They beat everything else!
Anyway, the test stand I bought (el' cheapo) was built for a 350. Hole on each side, wollering out the back holes, and flipping the dingo's and she'll be mounted. It would be easier if I had a welder and knew how to use it with a bit of metal laying around. I'll finish it up tomorrow and post a pic.
__________________
Old 03-10-2017, 02:02 AM   #33
justin71105
Year: 1987
Model: R10
Engine: 5.0
justin71105 is on a distinguished road
Default
Subscribing.
Getting ready to start putting togethor the parts needed for my trucks motor build. Going to start with fuel tank/lines then start getting motor/trans/harness togethor.
Sent from my SAMSUNG-SM-G930A using Tapatalk
justin71105 is offline   Reply With Quote
Old 03-10-2017, 11:19 AM   #34
Camar068's Avatar
Camar068
Year: 1986
Default
Got the new starter in yesterday. I'll have to take that side of the test stand apart to see if it will fit.
[update] word to the wise, put the starter on the engine before putting it on a $25 test stand. No modifying needed.
__________________
Old 03-20-2017, 09:38 PM   #35
Camar068's Avatar
Camar068
Year: 1986
Default
I'm not liking the cheap wire loom for my harness. Not that there's anything done with it, just I want to do something different. I've got some on hand, just don't want to. I've also got some mesh wire loom but I would have to DE-pin everything. Would look awesome but I can't imagine how much time it would take.
I tried spliting the mesh with a hot blade but it would be just as time consuming as De-pining. I made a jig and everything to split/melt/seal it so it wouldn't come apart.
Back to the drawing board before I suck it up and go plain wire loom. I may play with aluminum tubing. Split it and try bending it. I guess I could just get the engine in there and mock up some stuff for the bits I can't hide under other stuff.
__________________
Old 03-20-2017, 11:16 PM   #36
74 Shortbed's Avatar
74 Shortbed
Senior Member
Year: 1974
Model: C-10
Engine: 350ci/700R to be replaced with a 468ci
74 Shortbed is a jewel in the rough74 Shortbed is a jewel in the rough74 Shortbed is a jewel in the rough74 Shortbed is a jewel in the rough
Default
Have you seen this stuff?, real easy to install with the little tool and is very sanitary, I'll be using it when I do mine.
http://www.painlessperformance.com/webcatalog/braids
__________________
74 C-10 short bed (project)
74 C-10 short bed (driver)
62 Nova wagon
63 Nova wagon
75 Nova Custom
74 Shortbed is online now   Reply With Quote
Old 03-21-2017, 04:34 PM   #37
Camar068's Avatar
Camar068
Year: 1986
Default
seen something similar, just don't like the price lol.
[edit] by luck I came across this site. Prices more in my range. I compared the flexo F6 to the link you provided. Thanks, you got me looking.
https://www.wirecare.com/category/br...lit-tube-wraps
https://www.wirecare.com/category/sh...oise-reduction
__________________
Old 03-21-2017, 10:53 PM   #38
Camar068's Avatar
Camar068
Year: 1986
Default
Finally gettin' serious with the harness. Currently 30 connectors.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
vortec head swap, cam swap etc. few q's 1low4x4 Engine & Performance 15 08-20-2013 05:58 PM
