Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Engine & Performance > Engine Swaps (Gas) LS, Vortec, LT1 , etc.
Become a Supporting Member         Become a Preferred Vendor
Advertisements
User Tag List
Reply
Thread Tools Display Modes
Old 10-22-2016, 11:26 PM   #16
dougbert
Senior Member
Year: 1984
Model: K1500/nv4500/np241c/33x12.50/??? Gears
Engine: 5.3L
dougbert will become famous soon enoughdougbert will become famous soon enough
Default
Originally Posted by putt2014 View Post
Then what's the best option to run dual tanks?
I am looking for that solution myself as well
dougbert is offline   Reply With Quote
Old 01-11-2017, 04:40 PM   #17
Camar068's Avatar
Camar068
Year: 1986
Model: K10/350/700r4/np208/3.08/31"
Engine: 10 yrs Air Force
Camar068 is a glorious beacon of lightCamar068 is a glorious beacon of lightCamar068 is a glorious beacon of lightCamar068 is a glorious beacon of lightCamar068 is a glorious beacon of lightCamar068 is a glorious beacon of light
Default
Noticed this looking for FP regulator options. See post #20.....Pollak somethin or other.
http://www.gmsquarebody.com/forum/sh...gulator&page=2
Camar068 is offline   Reply With Quote
Old 01-16-2017, 09:46 AM   #18
throttle out's Avatar
throttle out
Year: 1987
Model: V10
Engine: 5.3 LS
throttle out will become famous soon enough
Default
Originally Posted by 86K1o View Post
Alrighty so i'm going to put in an order for fuel parts and this is whta I have so far:
1987 R10 Fuel Tank
1987 Fuel sending unit
Walboro 255 gss342 fuel pump
3/8 to -6AN QD is Russell 644123 (feed)
5/16 to -6AN QD is Russell 640863 (return)
Fragola Hose assemble AT165056ERL (hardline to rail feed)
TBI truck fuel filter(dont have PN yet, if anyone would suggest one)
2 of the AT991955ERL fittings to adapt it from 16mm o-ring to -AN
And I believe my truck doesn't have a return line but I'll check tonight.
Again, Thanks a lot everyone!
Heres what my list looked like.
#'s 1 & 2 look good on your list, my truck was an 87 so I already had them.
#3- AC Delco EP381
#4- 3/8 compression to -6an (SU feed)
#5- 5/16 compression to -6an (SU return)
#6- 20' of 3/8 (-6) stainless fuel line
#7- 3/8 gm quick disconnect to -6an fitting (ls fuel rail supply)
#8- 5/16 gm quick disconnect to -6an fitting (ls fuel rail return)
#9- 6, -6an straight fittings
#10 inline high pressure fuel filter
You want an AC Delco EP381 for a fuel pump, not the walboro you have listed. These can be had for $25 or so. Is what I used and WILL mount up to your sending unit like factory.
Better off in the long run to convert to AN fuel lines.
throttle out is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
vortec head swap, cam swap etc. few q's 1low4x4 Engine & Performance 15 08-20-2013 05:58 PM
