Undertightened cork gasket on TH350 and whole thing flooded, clean and reuse?
dkraven
Portland, OR
c25 Sierra Grande
Previously used a Moroso metal core gasket with a new steel pan and overtightened it. Decided to try a Mahle metal core cork one instead as I read cork is more forgiving. Took the time to hammer down the bolt holes and flatten the steel pan and then unfortunately was gunshy about tightening the bolts. As soon as I put new ATF in the entire seam started pouring out fluid.
My question is, is that cork gasket ruined now or can I clean everything up, install it again with a bit more torque, and try again?
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
I hate cork gaskets. My 2 cents. I don't run cork so I don't really know but you should be able to clean it up. It'll end up leaking anyways!
^Agreed, I hate cork as well. Every T350 I've worked on, we used a metal core gasket and put RTV on both sides.
legopnuematic
Licensed Junk Dealer
MO
Spencer
I’ve gone to using LubeLockers on my transmission pans and diff covers and so far I like them. More costly than other gaskets but they are reusable and made in the USA.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
I've had cork gasket problems on a 400.
What I did was a thin layer of Trans rtv on both sides and let it sit a few minutes then tightened. Stopped its drip issue.
Carb'ed Vortec 350
Over tightening can warp the pan, too, good thing you under tightened instead of the former. It's a very low torque spec on the pan bolts, I think 12 ft/lb.
Kheughens
Los Angeles, CA
kirk
I used both cork and rubber gasket but still had small leak issues (possibly pan slightly bent). I friend told me to ditch the gasket and just use permatext without the gasket. Worked flawlessly! No leaks! And cheaper.
bft305
ME
Ben
I have used both and they all leaked, tried flattening it out and no luck. Finally just used a silicone gasket and transmission gasket maker on both sides and no leaks yet.
Carb'ed Vortec 350
Not recommended, but if your pan is bent and can't be straightened, this is an alternative.
tenthirtytwo
Illinois
Pdub
The only time that I use a cork gasket is on an overhaul, meaning that everything is bone dry after a rebuild. On a trans service (fluid change) I'd only use the fiber/composite gaskets. It's been my experience that it's impossible to drain all of the fluid on a service. The residual fluid dripping from the trans will wet the cork gasket in ATF. Tightening the ATF saturated cork gasket almost always squishes the cork out as you tighten the pan bolts.
Edit: Someone mentioned flattening the pan. Sometimes the bolt holes in the pan need to be hammered down a bit. They can get a raised dimple around the bolt holes from over-tightening. You can set the edge of the pain on the edge of a bench, tap the pan rail (the surface that mates to the transmission case) at the bolt holes down flat with the pan rail.
tenthirtytwo
Illinois
Pdub
IMO, once the cork gasket gets saturated with ATF, it's unusable..
dkraven
Portland, OR
c25 Sierra Grande
Update. Spent a good deal of time flattening the pan and hammering down the bolt holes. Reinstalled the pan with the Moroso metal core gasket and tightened them incrementally and staggered to 6.5 foot pounds. (Moroso emailed me and said to tighten between 80-90 inch pounds, so I figured 6.5 foot pounds was fine). Two weeks later and no leaks! Thanks all for the help.
Carb'ed Vortec 350
Glad it worked out
Villano
